New Series III Owner (Changing Gear Issues)
  • StX_Rovers
    • Sep 2008
    • 67
    #16
    Originally posted by Les Parker
    It appears your Rover is RHD so you will need a different lever than Les mentioned. I am sure they can get it as when the lever on our 2A 109 broke we got a RHD shift lever from RN for a Series 3 as that is all that was available even then.
    Definitely check that grub screw as ours has come loose once. If it has loosened up, try cleaning up the threads and reassembling with just a drop of Purple Loctite (the weakest formula)
    • acorkran
      • Jun 2013
      • 6
      #17
      It is RHD and will look at the grub screws this weekend. Drove it the other day and still loose but manageable. Will post once I find out if grubs were the issue. Thanks again to all.
