Clutch questions
  • jimrr
    • Dec 2010
    • 487
    #16
    it can bypass (go from hi pressure area to low pressure area) in the master cylinder and you may not notice it till it starts coming out of the rear of the master cylinder (inside down the fire wall) .... in which case you'll be adding fluid too. if it bypasses at the slave cylinder then both sides of the slave cylinder will fill with fluid with the obvious result.
    if the wheel cylinders are leaking you'll eventually see it running out of the brake drum. ,
    my guess is you either have a heck of a lot of air in there (which isn't too hard to acomplish) or you are bypassing pressure at the pressure differential points.
    • nickhauck
      • Nov 2020
      • 11
      #17
      ok, so happy to get this problem resolved! so the fix was there was a bolt on the master cylinder that connects to the pedal that had worked its way loose almost to the point it was falling off. After fixing this and putting the master cynlinder back together, it seems like its back to new again! Turns out the clutch "slipping" wasn't really an issue at all and seemed "tight" again after the fix. Going to watch it closely to make sure nothing is leaking. Seems ok now, but there was fluid loss before, so I think there still might be a leak somewhere. But its driving like a tank again, so very happy. Thank you so much for everyone that contributed to helping out! Could not have done it without the community support!
      very grateful,
      Nick
      Nick Hauck
      '69 S2A 88 RHD
      • jimrr
        • Dec 2010
        • 487
        #18
        in the future: since that resevour doesn't take much fluid you can run synthetic in it, it won't absorb moisture ........ at least use dot 4.
        and when you bleed it make sure you're on level ground ..... as per prior: if the slave leaks, it goes inside the bell housing and you'll have to undo the drain plug for the bell housing to get it out. This is something we all need to do as you get water and all manner of krap in there. I just leave mine out as the rear main leaks and the xmission ........ and and and !!
        • roverp480
          • Jul 2020
          • 334
          #19
          If its a 2a the clutch slave is totally on the outside of the bell housing, so should be easy to check if its leaking. The S3 has the slave projecting into the bell housing & any leak from the seal will run inside .
