Series front door top windows
  • RoverKid_1972
    • Mar 2015
    • 38
    I’ve just installed the sliding windows using our host’s door top kit ( Window Fixing Kit Series Door Top Model #: RNA0349). Once installed, however, the glass alignment seems off. The rear pane slides far back enough that the vertical rubber seal slides past the end of the front pane (see photos). I believe I did the install correctly and followed along a YT tutorial by steamwally. My only thought is that more aluminum shims behind the vertical felt track would fix the issue but look pretty bad. Any ideas to fix or identify improper install would be greatly appreciated.
    Thanks, all.
    1972 Series III Frankenstein
  • Myron
    • 96
    It's been forever since I've done one of these, but I wonder if the vertical rubber seal isn't deep enough? Is it new, or are you re-using original?
    Or, perhaps there's too much of a gap between the two panes of glass.
    Myron
    • jimrr
      • Dec 2010
      • 493
      this is interesting. my door tops are pretty shot, probably fixable though (welding etc.) i found a pair on craigs list last month for $300 but i have not opened the box yet. hopefully i won't have
      a similar story to tell ?
