I ended up using an old set of brackets from a 250 and reworking them. I needed a new mount for the CS144 alternator and then ended up doing a lot of cutting and welding to make the power steering pump mount work. I'm adding an aircon compressor on the far side too. If I have one criticism of the Chevy L6 it is the minimalist approach to mounting holes for ancilliary brackets.
As well as manifolds I have raised the compression to a little above 9:1, a reworked head with 1.84I and 1.6E valves and lump port intakes, a comp cams 260H cam, HEI for spark and TBI for dueling. The spark and fuel will be run from a Megasquirt. It should push the old bus along quite nicely.
What needs done on the 101?
