great, thanks for the info... appreciated.
Ragtop install
1961 Ser IIa Hybrid Defender
1969 Ser IIa Bugeye
1998 Disco - ex wife :-(
2010 RR Sport Supercharged
http://mikerovers.shutterfly.com/ -
I'm getting PM'd about once per week since posting about a PDF file with instructions that I have. I believe those who have received it found it useful. Can Les or someone post it here so I don't have to email it out over and over?
Les, I sent it to you a while back. If you don't have it anymore I'll gladly send it again.
Thx.
1975 Series III 88" - SOLD
1990 RRC SWB
1994 D90 ST
2001 Porsche Boxster SComment
Seems i was shipped the Defender 110 top. Any way to modify it to work.. or send it back to the UK?
The new EXmoor top i bought doesnt have the recest holes in the front as pictured. Its solid across the front w/ a sewn rope inside to be tucked under the lip. When i tuck it under there.. then its not long enough to fit the door opening.
You could try a local trim shop, the best ones for this would be a boat trim shop.
All the best with it.
We have the Sand tops with windows due in later this week.Les Parker
Classic Exmoor-They are impossible to deal with. The only way to buy there stuff is through RN, otherwise be prepared to get screwed.Seems i was shipped the Defender 110 top. Any way to modify it to work.. or send it back to the UK?
Last edited by Bertha; 08-17-2010, 07:46 AM.1965 109 2door hardtop (restored years ago)
1971 88 (restored and as new)
1967 88 (the next project)Comment
I would send it back and get the correct one.
If you told them the year/make/model of your truck, they should have sent you the correct top. It should fit without modifications - the Exmoor tops are expensive and modifications aren't cheap (if they're done by someone who knows what they're doing). Having someone modify the one you've been given could just F it up.
If you have a solid leading edge, it sounds like they gave you a top for the newer style Defender header, not for a Series. Mine had the holes like the one pictured.
The new EXmoor top i bought doesnt have the recest holes in the front as pictured. Its solid across the front w/ a sewn rope inside to be tucked under the lip. When i tuck it under there.. then its not long enough to fit the door opening..
1990 RRC SWB
1994 D90 ST
Has this pdf been posted somewere on this sticky ,I don't seem to see it. I don't want to pester Wooday for If its all ready on hereI'm getting PM'd about once per week since posting about a PDF file with instructions that I have. I believe those who have received it found it useful. Can Les or someone post it here so I don't have to email it out over and over?
Thx
Thanks SeanSean
1963 88'' IIa daily driver
1970 88"
1971 88"
authenticstoneworks.comComment
Sean
1970 88"
1971 88"
It's in Post #2.
Here it is:
Here is another PDF showing and install.
Birmabright Brotherhood
