Machined up a set of the lower brackets to mount the seat belt coils, and mounted them properly so now the belts will do something. Next up is install some interior lighting and drop the gas tank and install the 2" receiver assembly.
getting ready for winter
early christmas present from my wife
aaronLast edited by 73series88; 01-15-2011, 06:53 AM.73 series III 88 2.5 na diesel daily driver
67 series 2a 88 RHD sold
88 RRC sold
60 mga coupeComment
I did not know that RN sold those. Does it feel lilke it works? I would love to get one if it helps warm the thing up a little.
Thanks,
Gary"I can't believe I'm sitting here, completely surrounded by no beer!" -OnslowComment
I have a muff on my IIA, and it does help the engine come up to tempurture faster. The key is in watching your temp gauge though, to ensure you have the flap open enough that it doesn't run too hot after it comes up to tempurature.Bad gas mileage gets you to some of the greatest places on earth.Comment
rad muff definately makes a difference.
aaron73 series III 88 2.5 na diesel daily driver
88 RRC sold
60 mga coupeComment
Fixed a bunch of electrical issues(what's new)including the starter. Hopefully that's it do awhile my hands can't t take the feel of cold steel like they used to.Comment
When the points open, the magnetic field in the primary of the coil collapses, and thru the secondary winding, causes the spark. Breaking the magnetic field would cause a huge arc at the points, the condensor absorbs the enrgy, protecting the points from arcing. When the points close again, the energy stored in the condensor discharges, ready for the next opening. Some people mistakenly think the coil fires when the points close, but no, it fires when they open.Comment
You made that way to easy to understand. I figured it would need it's own thread to get out correctly.When the points open, the magnetic field in the primary of the coil collapses, and thru the secondary winding, causes the spark. Breaking the magnetic field would cause a huge arc at the points, the condensor absorbs the enrgy, protecting the points from arcing. When the points close again, the energy stored in the condensor discharges, ready for the next opening. Some people mistakenly think the coil fires when the points close, but no, it fires when they open.
finished installing the driver seat belt gusset bracket and lap belt.
has anyone else installed the RN proline belt?
the seat belt harness bolt that was included is much too long. so long in fact that when the bolt threads through the bracket and reaches the seat box, the head of the bolt prevents the door from closing. i had to re-fabricate the bolt to make it work.Comment
