  • Jeff Aronson
    Moderator
    • 569
    #31
    Driving around in the snow and ice is routine use of my II-A, hardly worth mentioning - and I do have to earn a living through the Rover .
    I, too, live in a state with an annual inspection ritual. Some of my maintenance is getting it ready to pass this week!
    However, next month is the Maine Winter Romp, a chance to hit the trails and who-knows-what conditions in the woods of central Maine.
    Jeff
    Jeff Aronson
    Vinalhaven, ME 04863
    '66 Series II-A SW 88"
    '66 Series II-A HT 88"
    '80 Triumph TR-7 Spider
    '80 Triumph Spitfire
    '66 Corvair Monza Coupe
    • TeriAnn
      • 1087
      #32
      Originally posted by SafeAirOne
      Interesting that most of the replies to this thread are maintenance-related as opposed to the much more desireable "driving and doing fun stuff"-related. Perhaps everyone does their heavy maintenance during the winter??
      In my case I'm coming into a little money which is paying for some much needed but previously unfordable maintenance items and I'm fine tuning some gear ratios to better fit the kinds of off road driving I do. Then when the maintenance is completed I plan to take the Dormie out on a multiple month trip.
      In my case the timing has everything to do with some extra money becoming available.
      Teriann Wakeman_________
      Flagstaff, AZ.
      My Land Rover web site
      • LaneRover
        • 1743
        #33
        Actually you may be able to help me decide what I am going to do!
        I blew out the muffler the other day. When I bought the truck it came with a SS muffler with a crack in it where the tailpipe comes out of the muffler itself (see pic). At the time I just bought another mild steel muffler from our hosts to get the truck inspected. Now I figure that I will repair the SS muffler and put it back on.
        I believe the crack was caused by a combo of the muffler being incorrectly supported when and the strikes which caused the dents in it.
        My question is, has any one done a quick repair weld on a muffler like this and what sort of wire should I use? I am a fair/unpracticed welder using a 110V Lincoln Mig welder with fluxcore wire.
        • TeriAnn
          • 1087
          #34
          If it were me I'd just take the truck down to the local muffler shop & tell them I want a new free flow muffler and if they show you that the exhaust tubing is also gone, I suggest going with the next diameter larger pipe.
          They can generally do a better job than most people can for not all that much more than buying replacement parts at retail. Over time I've become more choosy over which battles I'll fight and which I'll farm out.
          Flagstaff, AZ.
          • LaneRover
            • 1743
            #35
            Muffler shop may be an option as I have done that with my 109 P-up. But since I have the muffler (and have just had my 1 year wedding anniversary) I figured that I would try to save a bit and see if fixing is an option.
            If I do go to the muffler shop I most likely would have them do the next diameter pipe as more flow definitely doesn't hurt!
            • Thomas
              • Jan 2010
              • 2
              #36
              Well, I just started my series III 109" for the first time in nearly six years, I change the spark plugs and put some new gas in and she started right up, maybe took me fifteen minutes to get her purring. Gotta love my landy!!!! I just need to get the body back together and she'll be back on the road just in time for summer...................I hope! So for all you procrastinators out there, and we all know who we are, there is hope!!!!
              • Hawaii_SIII
                • Nov 2007
                • 49
                #37
                I installed some rear mud flaps today and adjusted the clutch pedal play. As always, while tooling around the engine, I noticed a leak by the #3 head bolt just under the #3 fuel injector. It looks like i need to retorque the bolt. I don't feel much like taking the injector off to check the torque. Does anyone have the tool shown in the green bible that allows torqueing of the bolt without removing the injector?
                • thixon
                  • 909
                  #38
                  You can make one. Just bend up a good wrench with the "smoke wrench."
                  Travis
                  '66 IIa 88
                  • Hawaii_SIII
                    • Nov 2007
                    • 49
                    #39
                    I would be all for making one but lack two major items. First, I don't own a "smoke wrench" (propane torch I assume) and secondly haven't seen anyone do it before. If I were to use a cheap wrench, would the open end fit the torque wrench?
                    • Les Parker
                      • May 2006
                      • 2020
                      #40
                      Rover out of the back yard !
                      So, after 2 hours of snow blowing and digging, the Airportable is now out of the back yard and getting ready for a new home
                      Explore elwpea’s 29 photos on Flickr!
                      • scott
                        • 1226
                        #41
                        maybe a crow foot with a 6" extension will work
                        '64 Series IIA 88 Canvas Tilt
                        '68 Series IIA RHD Ambulance
                        '76 Spitfire 1500
                          #42
                          Funny--It only took me an hour of snow blowing and digging to make a spot to park it here at my house.
                          • LaneRover
                            • 1743
                            #43
                            Well, my Rover no longer sounds like a lobster boat! Today I replaced my muffler. As you can see by the pic, even without the backfire something tells me I would have been replacing this muffler sooner rather than later.
                            I called around to some welding stores and got the answer, they don't make SS welding wire for your size machine. Since I wasn't about to go and buy a new welder to fix this muffler I went ahead and gave a shot at welding the SS muffler with what I had on hand. We will see how well it lasts!
                            Took it for a drive and so far so good!
                            • badvibes
                              • Mar 2007
                              • 364
                              #44
                              Over the last 3 days I have:
                              1. Replaced seal on the right rear wheel, degunged brakes, reassembled
                              2. Repaired and replaced broken alternator mount
                              3. Oil change and re-oriented the spin off adapter so I don't burn up my motor like someone I know.....
                              4. Mounted bracket to put spare tire behind the bulkhead
                              5. Adjusted turn signal mount
                              6. Adjusted timing
                              Truck is running good, I'm a happy Rover guy! I know this is like 2 hours work for a real mechanic but it probably took me 10-11 hours over 3 days.
                              1991 Range Rover Hunter
                              • gudjeon
                                • 613
                                #45
                                Depends on where in the system you need to join, You can always use clamp on type piping to fix it.
