  • Terrys
    • May 2007
    • 1382
    If you're only at the paint-stripping stage, why worry about puting the mirrors on now?
    • LaneRover
      • 1743
      Went to my storage garage in Ocean Beach to clean some stuff out and thought, "I REALLY got to get this one going!" If I did get it going then even with tax and insurance I would still be saving $$$ because I wouldn't have to rent that garage anymore!!
      So hopefully I will start working on that '58 soon!
      Brent
      • jac04
        • 1884
        ...because military vehicles were usually painted immediately & often after rolling off the assembly line. Stripping the military-applied paint often reveals factory paint in exceptionally good condition for its age. So, roverlandpark is giving his vehicle a reverse paint job. Hopefully we'll see some photos soon.
        • cachinfool
          • Aug 2007
          • 42
          Started fitting the right side footwell, still waiting for the left side lower door post before I can start on that side. I also discovered you can never have too many clamps and never have that one clamp the would make everything sooooo much easier.
          How come dumb stuff always seems so smart when your doing it?
          David Crockett
          • siiirhd88
            • 382
            After dinner I test fitted the new Pangolin winch bumper and Warn 8274 winch to my SIII 109. I have to pick up a couple of slightly longer winch bolts and complete the winch wiring to test it.
            '96 Disco SE7
            '80 SIII 109
            '75 SIII 88 V8
            '68 SIIA 109
            • roverlandpark
              • Feb 2009
              • 38
              I couldn't stand that there were twelve layers of paint flaking on the garage floor. With the paint stripped back, I'll have a more tidy looking vehicle to drive around for the next few months as I get more parts together for the restoration. Also, the Lightweight had only one mirror and it and the rear-view mirror were shot. I'm not complaining, I like finding excuses to buy parts...
              1979 Land Rover Half-Ton GS
              • bpj911
                • May 2009
                • 128
                rover fixing
                Door seals, rebuilt injectors installed, oil change , Maradyne heater, cut 1/4 rubber floor mats, built new airbox to eliminate oil bath, relocated one battery under seat, built cables to run two batteries in parallel, removed top for headliner,
                All this wasn't done today but recently
                To go: lots
                • Mojave Rover
                  • Feb 2008
                  • 23
                  Finished removing rear axle from '97 Disco this evening. Took care of front this past weekend. Taking both to welder to remove coil fixings for a parabolic set up. Flip, my retired pipe welder and a real magician, will work on finishing mounts for rebuilt Defender 200tdi, new r380 (short bell housing), and the Disco's lt230. Getting closer...
                  It's taken a long time to get to this point.
                  • roverlandpark
                    • Feb 2009
                    • 38
                    Originally posted by jac04
                    ...So, roverlandpark is giving his vehicle a reverse paint job. Hopefully we'll see some photos soon.
                    Look for a separate post on Sunday. With the military paint gone, I've been over the body several times. There are lots and lots of issues to be addressed and there will be several photos.
                    • masonater
                      • Nov 2007
                      • 329
                      Disconnected everything but the motor, transmission mounts, and cross member in preparation for pulling them out as one unit (i hope) tomorrow. I checked and rechecked about 3 times that i got everything but ill know for sure tomorrow when i hook the 6000lb crane to it!
                      1970 Series IIA 109 EX-MOD
                      1971 Series IIA 109 EX-MOD
                      1982 Mercedes 300TD
                      1989 RRC
                      1993 D110
                      1994 RRC LWB
                      1995 RRC LWB
                      1995 RRC LWB
                      1995 Disco
                      1996 GMC 2500 Suburban
                      1996 Disco
                      1997 Disco
                      2001 RR P38
                      2005 LR3 HSE
                      2006 RR HSE
                      • jac04
                        • 1884
                        Installed a set of Mintex brake shoes on my 11" front brakes. I had the original half worn riveted type shoes in there, but figured since all other components were brand new I better have new shoes as well.
                        • czenkov
                          • Sep 2008
                          • 148
                          Recently: Door seals, worked through a heater power issue, and clutch issue.
                          Last Night: Installed Belleview Winch - works but needs new cable and probably disassembly and cleaning.
                          Today: 5 Mile Pass. Navigated hills, mud, snow and rocks.
                          It was a GOOD day!
                          1960 88" SII Pliny the Elder
                          1997 D-90
                          "Fear profits man, nothing"
                          • brucejohn
                            • Jul 2009
                            • 215
                            It was a GOOD day!
                            Any day on the trail of the Pony Express is a good day, I am jealous. =)
                            1982 SIII 109 RHD petrol project.
                            • Pete
                              • Jan 2007
                              • 93
                              Does admiring the new Marsland Galvanized chasis that showed up at my door yesterday count???????
                              Pete
                              • solihull109
                                • May 2007
                                • 191
                                Pete
                                Whew, I bet the UPS guy was happy taking that thing out of his truck
                                www.downeastcoachworks.com
