I am just at the end of doing this to my S3 109 SW with 200TDI,LT77,LT230
I used the following parts.
P38A Steering box
P38A intermediate column
P38 hoses (modded to fit).
P38 Rerservoir and bracket
200TDI PS pump. Type that uses a banjo bolt for high side
Defender upper steering column. Outer tube is modded with top of old column for needle bearing. Shortened and resplined to accept Series wheel and so that trim fits.
Custom tie rod as it is a lot further between the swivel bracket and the new P38 pitman arm.
Custom 3/8" plate that goes on outside of frame and then uses tubes for stengthening the 1/2" bolts that hold it to the frame. The two upper bolts hold the box to the plate. The lower front bolt screws into the tapped hole in the plate and the side of the frame. The lower aft bolt goes all the way through the frame, is also tubed, and secured on the inside of the frame. The tubes were done so that they were pushed through from the outside but butted up agains the frame on the inboard inside. Did not have to weld anything. Once all 6 1/2" bolts are tight the plate or box are not going anywhere.
An oddity of the P38 box is that when the box is centred the pitman arm is about 10-15 degrees towards the outside. The geometry is close but you will have more turns going right than left. This is normal.
The pump is fitted to the proper 200TDI plate and bracket. My 2.5 petrol has the bracket on it too.
I have a load of photos and sketches I can send you to make my explanation clearer. Beware this is not a cheap project even when you know all the pitfalls. One thing to remember is that when you make a modification at one end it goes down the line and seems to never stop. I do think this is worth doing. I have heard that PAS will break the swivel stops so you should also upgrade the bolts for them.
Good luck
Bill B
P38A Steering box
Good luck
Bill B
