So, this will be this weekend's project. I will be replacing the right side quarter panel due to that riveted repair panel under the gas filler assembly and also corrosion around the circled riveted areas.
I have been advised from multiple sources to eliminate the Series III seatbelt reinforcement brackets.
Are those to be found behind the red circled areas? I am hoping to eliminate these sets of rivets.
The right side will be a new panel, but the left side I will have to cut out these sections (as the same corrosion exists in the same 3 areas), replace from panel from behind as did Martin on this board, and use a thin film of skim (could locate no LH panels anywhere).
Please let me know if all 3 red circled areas can be removed.
Thanks!
Julian
Thanks!
Julian
