You're still evading the driving requirements question. It's too hard to say what's right if you are not forthcoming.
Do yourself a favor and drop the NV4500 notion. I hate to say it's a dumb idea, but there are far better options. I'd rather see you put an NP 4 speed in it than that 4500. First gear on the 4500 is almost useless to you. You'll probably find yourself starting in second gear on the road, and find few instances where you need it off-road.
Salisbury vs Rover diffs. Salisbury axle is stronger because the axle shafts are fatter and the ring gear more robust. Ratio changes are more problematic with them although they can take a regular DANA 60 ring and pinion. The ARB locking diff for them is good, but a Detroit locker in the rear is pretty much bulletproof and requires no external plumbing. If I am not mistaken TAW uses automatic lockers both front and rear and she runs what I would call a heavy truck on them without trouble.
Rover diff you can plunk a 24 spline carrier in and use aftermarket axle shafts but a full set will set you back about a grand. To me that's a lot of money, and they aren't necessarily unbreakable.
The elusive leafer salisbury front. I know of exactly one vehicle in the USA with one. Dan Rao's truck has it and it is impressive. Whether you could ever find one or not, I wouldn't plan around that. It would be easier to have a Dana 60 front axle custom built.
There's one like that on the late Mike VanCuren's monstrosity ( which I had the experience to run around the Cove in at Conclave)
