Ragtop install
  • jac04
    • 1884
    #61
    Originally posted by dabawei
    Can any one say the difference between Exmoor trim canvas product for S2a, there is an standard cotton and new line called deep weave canvas?
    It's my understanding that Exmoor Trim is now using the 'deep weave' canvas only and they are no longer producing tops out of the old material.
    • dabawei
      • Dec 2011
      • 57
      #62
      Exmoor trim vs Britpart
      Hi,
      What are the difference between Exmoor trim ragtop and Britpart ragtop for series 2 88' WSW? In terms of quality, colours and final look?
      BR
      Ahmad
      • Escargo
        • May 2008
        • 65
        #63
        Just one quick question. Both the "Proline" hood sticks and tilt went together pretty well but... Where does the rope(line if you are a sailor) go that comes out of the bottom front corner of each side curtain? It is too far forward of the closest hoop to tie to it.
        Hans
        • disco2hse
          • Jul 2010
          • 451
          #64
          See the second video I posted in posting #41. At 2:00.
          Alan
          109 Stage 1 V8 ex-army FFR
          2005 Disco 2 HSE
          • Escargo
            • May 2008
            • 65
            #65
            Can't find it. Can you tell me in words?
            • disco2hse
              • Jul 2010
              • 451
              #66
              Tell you what. You make more effort, so I don't have to.
              Try scrolling to the top of the page
              Alan
              2005 Disco 2 HSE
              • Escargo
                • May 2008
                • 65
                #67
                Gotcha. Thanks
                • blue bomber
                  • Dec 2011
                  • 48
                  #68
                  I have a helpful hint when using these canvas tops. I was experiencing exhaust stink wafting into the cab any time the throttle was released. This may not be an issue with a stock style pea shooter muffler and tail pipe. But in my case, both the 2.25 and the 5.7 vortec, were killing me!!After multiple attempts to figure out how defeat the stank!! It took a quick history lesson to smart me up. If you look at a WWII MB jeep,the canvas is open except the rear. It is pulled down. Magic!! I just rolled it down and now it's gone. I can haul butt down dirt road without a dirt swirl coming in the back. Check out these images. I hope this is helpful .Click image for larger version
ID:	167109Click image for larger version
ID:	167110Click image for larger version
                  Sent from my iPhone using Tapatalk
                  • Broadstone
                    • Jan 2009
                    • 216
                    #69
                    Put a soft top on for the first time yesterday and unless I am missing something I am not to impressed with how it fits along the windscreen/doortop corners. It is brand new though poorly stored by the previous owner so has discoloration. It seems to be that the corners do not stay where they are meant to. I have watched an install video and they say it will be a bit loose there to allow for shrinkage. As far as I see it if it shrinks it will be even worse there. I posted pictures as it lays by itself but also how easy it is to pull the corners up and I assume wind when traveling would cause it to pull up even more there. The strap along the windscreen and drain channels is tied back as instructed and makes no difference. Is this just how they are? and why after 60+ years of soft tops is there not a better design for a nicer fit?
                    1973 NADA 88
                    • jac04
                      • 1884
                      #70
                      ^^The front piece with the 'tines' on it should be up against the windshield frame. On my SIII Lightweight, this piece is actually riveted to the windshield frame using the hole at each tine. This will bring the front edge of the top down, and will keep it in the gutters as well.
                      • Broadstone
                        • Jan 2009
                        • 216
                        #71
                        Thanks for the reply, so if I follow you correctly I would have to bend the front rail downward to get it to touch the windscreen frame and then drill into the frame and rivot it? I am just not sure I want to drill my windscreen frame as now that its on I am kinda thinking its not as practical for me as the truck top I run it with.
                        1973 NADA 88
                        • jac04
                          • 1884
                          #72
                          I would bend it so that it is tight up against the windshield frame. Since you switch between tops, I agree with not riveting it.
                          • jimrr
                            • Dec 2010
                            • 490
                            #73
                            I formed my topless frame out of aluminum tubing, getting the bends right was mostly luck, then i went to a fabric shop and I think it was about $700 they put straps on a marine vinyyl material I'd selected and for probably about $750 I have a factory looking rag top that always gets lots of thumbs up!
