That is great.I got $50 in Dunkin Doughnuts gift cards, but not one red cent for Lowes,Hunky Dory, or any other authorized Rustoleum agent. Do you know how hard, not to mention embarassing it is standing just upstream of the drive-thru with your gift cards, trying to find some poor slob who doesn't want his Lowes card?
'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
busy weekend
ok so liam and i did some work this weekend
overdrive is in (love it)
went in with no problems at all.
put a new mirror on the left side so im not blind over there.
i got some used sun visors from a cj7 im going to put in this afternoon
if the weather holds out we wil try and get the new door seals in tommarow. see yah
aaronLast edited by 73series88; 01-15-2011, 06:53 AM.73 series III 88 2.5 na diesel daily driver
67 series 2a 88 RHD sold
88 RRC sold
60 mga coupeComment
sun visors
88 RRC sold
60 mga coupeComment
I still say we should use boating nomenclature. Port side. Port side!
Aaron, I'm glad that OD is making you happy. Be sure to watch the levels for the first few thousand as it's been out of service for a good while.
thanks
tim
yes i mean starboard.
aaron73 series III 88 2.5 na diesel daily driver
88 RRC sold
60 mga coupeComment
Spent last night and this afternoon wiring in a set of 4 led strips from Ikea for interior lighting as well as redoing a bunch of generations of PO wiring. The Ikea LEDs were intended for domestic use but didn't work out, especially when I noticed they were 12volt. I routed the wires through the roofs inner cross u channels (no liner) to keep it somewhat clean. 2 LEDs up front above the driver and passenger door and 2 staggered in back. Works quite nice and was pretty cheap for LEDs.
Also started installing a cigarette lighter, spent a long time debating where to put the plug and decided to make a new plate where the RHD handbrake cover is on the passenger seat box. Enough holes drilled in the truck already. Had to stop in the midst of routing the wire to the main fuse terminal, but when I finish I'll take it for a spin and try it out on a cheap cigar._________________________________________
1986 3.5l 110 SW Austrian FeurwehrComment
I think the cable wants to go under the overdrive, near the face of the transfer case. If you look over the case of the overdrive, I bet you will see the wear marks from where the speedo cable was rubbing in it's prior installation.Comment
Started to swap out the rear crossmember on my ex mod 109. Took longer than i thought to cut the old one off. Used my desert tan powder coat on a bunch of interior parts and they came out great. Once i get the new crossmember on and fix one of the front horns it will be put back together time!Last edited by masonater; 01-04-2011, 12:32 AM.1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
I hooked a wire (aka the key) to the fuses, pushed the magical button, and it cranked right up, I pulled it out from the garage, pushed my four wheeler into the garage right behind it, then pulled it back in the garage for it's hibernation period... I will miss it for a month or two.WAR EAGLE!
65 IIa 88
95 RRC 25th Anniversary
98 Discovery LE7
00 DII (Sold)Comment
