  • scott_b
    • Jan 2011
    • 15
    Finally home
    I've been lurking on here quite a while, just waiting for the day when I could post in this thread. Well, the auto transporter finally delivered so I am now officially a LR owner. So what did I do to my Rover today? I brought it home.
    scott_b
    1975 SIII 88" RHD
    • stonefox
      • Jul 2010
      • 450
      Scott,
      Nice truck.Good luck with it.
      Just a warning ,your life will never be the same. Welcome to the dark side
      Sean
      1963 88'' IIa daily driver
      1970 88"
      1971 88"
      authenticstoneworks.com
      • albersj51
        • May 2010
        • 687
        Got the old frame and front leaves off. Started unpacking one of the springs and set up an acid bath to dip them in to make the rust removal process a little easier.
        • masonater
          • Nov 2007
          • 329
          Finished resealing the gearbox and put all my powder coated goodies on. Also got the rear main seal out of the engine and will install the new one tomorrow.
          1970 Series IIA 109 EX-MOD
          1971 Series IIA 109 EX-MOD
          1982 Mercedes 300TD
          1989 RRC
          1993 D110
          1994 RRC LWB
          1995 RRC LWB
          1995 RRC LWB
          1995 Disco
          1996 GMC 2500 Suburban
          1996 Disco
          1997 Disco
          2001 RR P38
          2005 LR3 HSE
          2006 RR HSE
          • TeriAnn
            • 1087
            Originally posted by smukai
            Started her up in the -14F weather here in Colorado. Noticed that my driver side seat cushion has never been so firm. Then realized that the parking brake was frozen in place. Put her in low range to pull it out of the way and then climbed into a car with heated seats.
            I'm getting soft....
            Know what you mean. When the kit comes in from Exmoor, heated seats in my 1960 109 will be part of the reupholstery job. Already converted to heated windscreens and Defender door seals.
            With new seat covers and door trim I'll hardly recognize the interior. Which will be a good thing.
            • mrdoiron
              • Dec 2009
              • 446
              GOODBYE SU Carbs, hello Edelbrock 4 bbl
              Finally had it with the sensitivity of the SU Carbs, so popped on a new Edelbrock manifold and 4 bbl...
              Much less maintenance, and the Frankenstein RR V8 in the old 61 seems to love it also....
              mike
              1961 Ser IIa Hybrid Defender
              1969 Ser IIa Bugeye
              1998 Disco - ex wife :-(
              2010 RR Sport Supercharged
              http://mikerovers.shutterfly.com/
              • siii8873
                • 1013
                Bugeye restore work
                Started restoring parts for my 69 Bugeye.
                I had the brake and clutch towers/pedals, bulkhead supports and bulkhead galvanized. This weekend I tapped out all the holes and reamed the bushing bores on the towers/pedals, rebuilt the fuel pump (will use as a spare), disassembled and cleaned steering box (think I will leave this unpainted), Painted tower parts, steering gear parts and reconditioned brake booster, and rebuilt the clutch master. Ordered some cleaner and conditioner for pretreating galvy parts for painting.
                THING 1 - 1973 88 SIII - SOLD
                THING 5 - 1958 109 PU
                THING 6 - 1954 86" HT
                • siii8873
                  • 1013
                  BTW here's a picture of the bulkhead also.
                  • siii8873
                    • 1013
                    OOPs forgot one step. after rehabbing the holes on the other parts I see some challenging areas to renew on the bulkhead. Vent pin and hinge pin areas will be tough to get a drill into. Stonefox had a good suggestion to make / use a tool with a flexable shaft. I will not be able to get a drill motor in position to drill them out square. Any other suggestions would be appretiated.
                    • HybridIIA
                      • 98
                      Stonefox has a great suggestion. This guy did a very nice job of documenting the flexible drill bit he made .... http://www.gottdenerdesigns.com/bulkheadswap1.html
                      '62 109 - coil sprung
                      '64 88 - coil sprung
                      • Cutter
                        • Feb 2009
                        • 455
                        Buttoned everything up after my hellish gas tank/tow hitch install which of course included removing a wing while I waited for parts and installing a new-to-me exhaust manifold that cured an awful leak at the down pipe flange. Also took my distributor apart to replace a mangled mechanical advance spring with one I got off a second hand unit, though I don't think it is the correct version of the dizzy so the spring may be wrong. Timed the engine for the first time solo and it runs fantastic. Not sure if the exhaust leak could really be to blame for that, the timing, or a combination of the two.
                        • rosims
                          • Jun 2010
                          • 71
                          Got Engine in
                          Got engine and trans in,
                          sigpic
                          2006 LR3
                          1967 109 Station Wagon
                          M37B1
                          M38A1
                          • Momo
                            • 347
                            Today I made a wiring harness for my alternator conversion on the 109 pickup. Now I just need to complete the connections and tighten all bolts.
                            Yesterday I got some minor work done on the 88 project- I dismantled the radiator/breakfast assembly and got about halfway through getting the engine ready to pull.
                            The radiator was an el cheapo aftermarket job, and the cooling fins were so far gone they crumbled like dry leaves. It went in the dumpster. The breakfast is rust free and will go to the galvanizer along with two bulkheads (one a spare I am hoarding) and other various bits.
                            Meanwhile all my parts have arrived for the gearbox rebuild on my 109 wagon. That will get done hopefully next week.
                            Owning more than one Land Rover is like herding cats...
                            '60 SII Station Wagon
                            '64 SIIA 109 Regular
                            '68 SIIA 88 Station Wagon
                            • JackIIA
                              • Dec 2008
                              • 498
                              Cut up the old frame on my 88.
                              1970 88 IIA
                              • Terrys
                                • May 2007
                                • 1382
                                That looks like a pretty decent rear crossmember. Anything has to be better than the junk replacements.
                                I hope there is something seriously wrong with that front bumper that doesn't show in the picture, because it sure looked like it used to be better than mine.
