  • RoverForm
    • Jul 2010
    • 348
    looks like it was a busy sunday...
    Originally posted by jac04
    I bought a Roverdrive!
    Can't wait to install it.
    i need to get one of these. you have any specifics on the model/price? pm if needed.
    Originally posted by Partsman
    Pulled the steering wheel off and refurbed that and then took apart the signal mech and cleaned that up...ordered a new signal wheel from Pangolin.
    i just bought a refurbed banjo. you have any pointers or tips on the removal and replacement of the wheel? pm if needed.
    • Partsman
      • May 2011
      • 329
      Removal of the wheel was easier than I expected. Hmm...tips: after removing the horn button, and the collar bolt, spray WD40 inside where the wheel goes onto the column, use the penetrating ol when putting it back too. before you remove the old wheel mark where the bottom of the wheel is on the column with masking tape.
      Series 2 Club Forum
      Andy The Landy Shop
      • stonefox
        • Jul 2010
        • 450
        After removing the bolt,gently tap a screw driver into the slot to wedge it apart (slightly) it should wiggle off.When you replace it make sure it seats back down so the bolt grove lines up with the bolt.This would also be a good time to find the center of the steering box and realign the steering wheel accordinly.
        Sean
        1963 88'' IIa daily driver
        1970 88"
        1971 88"
        authenticstoneworks.com
        • mrupstate
          • Sep 2011
          • 9
          I drove mine down the road and found it was leaking more oil after the rear main seal was replaced then before. Guess time to take it all back out again.
          • Skookumchuck
            • Oct 2010
            • 269
            I added 1/2 a liter of Oil. She is a good old rover and leaks enoungh to keep me honest and pay attention to her.
            1968 Series IIA
            1987 D90 Kid's project
            • Billy5
              • Aug 2010
              • 172
              I adjusted the timing, think its right, adjusted carb ( weber), and gave an overall check around. Gearing up for my fall/winter service.
              1969 Series 2a Bugeye
              • Winemark
                • Feb 2010
                • 83
                Phew...actually got my sticker. Guy at garage couldnt find headlights, figure out wipers or even start my Series so he just gave me another sticker. I love my truck
                Best,
                Mark
                __________________
                1965 Series IIa
                • Ncrover725
                  • Jun 2011
                  • 259
                  Water Pump
                  Changed out the water pump. Now trying to stop one of the radiator hoses from leaking.
                  1971 Ex Mod IIA 109
                  1985 D110
                  1998 D1 (Sold)
                  • jac04
                    • 1884
                    Finally finished my Roverdrive installation, which spanned several days and too many hours to mention due to some unforseen circumstances.
                    Went out for a 30 mile drive on the highway and cruised comfortably at about 65 mph. I've had Fairey ODs in my other Rovers, and all I can say is Man, this thing is quiet! I actually passed 7 cars on the highway. And, no, none of them were broken down on the side of the road. Having the Roverdrive only makes me want more power!
                    • slorocco
                      • 208
                      Story of my life, ordered more parts. Will start working on the bell housing and overdrive swap to the new tranny tonight.
                      • crankin
                        • Jul 2008
                        • 696
                        Jeff,
                        You can't think that you are getting off this easy, huh?! Pics please.
                        Birmabright Brotherhood
                        Clint Rankin - 1972 SIII SWB
                        • mrdoiron
                          • Dec 2009
                          • 446
                          Nice work JEff, only more envy !!
                          1961 Ser IIa Hybrid Defender
                          1969 Ser IIa Bugeye
                          1998 Disco - ex wife :-(
                          2010 RR Sport Supercharged
                          • jac04
                            • 1884
                            Originally posted by crankin
                            Pics please.
                            Funny thing - Believe it or not, I didn't take any pictures of the installation.
                            • Terrys
                              • May 2007
                              • 1382
                              Jeff,
                              I saw it the other night. It's disgusting; all covered in grease and oil.
                              not
                              • crankin
                                • Jul 2008
                                • 696
                                not
                                Jeff, speaking of this. How is you specially constructed tranny oil pan catcher working out?
