What's this lever?
  • amcordo
    • Jun 2009
    • 740
    #46
    God. I was happy that this board was my last refuge from inflamatory political talk on the web. Thanks for destroying that.
    Originally posted by scott
    Why don't we ask our president? He seems to know these things. What was it he was saying the other day? "Put it in D for deeper in debt or R for recovery
    • scott
      • 1226
      #47
      Gee I guess this means ya also don't wanna see any god jokes. Sorry I hope I can change, oops ther I go again.
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
      • amcordo
        • Jun 2009
        • 740
        #48
        Unstoppable!
        • usadventureracing
          • Sep 2008
          • 106
          #49
          Ok, just realized my overdrive has been in the forward position for a while. I assume this mean it is engaged, I have never used it so how do I disengage it?
          Also to fill the unit with oil is the filler hole on the top. I installed a cubby box so I will have to fill it when I am underneath.
          Thanks, Brett
          1968 Series IIa 88 w/ hardtop - SOLD
          1970 Series IIa 88 (parts car)
          M416 Trailer
          2008 Toyota FJ
          2009 Volvo C30
          1983 D110
          http://68landy.blogspot.com/2010/01/blog-post.html
          • scott
            • 1226
            #50
            if it's just sitting there then just pull the leaver straight back. the clutch may help. if you're rolling along then engage clutch pull leaver back. with the o/d disengaged you should notice an increase zippiness. note there is 3 positions for the o/d leaver. back disengaged, forward engaged, middle neutral no go everything just spins. i found this out once after messing with clutch hydraulics thinking the clutch was stuck. turns out i just bumped the leaver while getting junk out
            '76 Spitfire 1500
            • Tim Smith
              • 1504
              #51
              As a helpful bugger, I should also note that the lever could be stuck. If you find the lever not able to move, then try to get some lube in the joint of the stick you are pulling. Otherwise you might think the stick is useless.
              • Lord Icon
                • Jul 2008
                • 176
                #52
                giggle
                Insert crude viagra joke here....
                Whence came you my brother ? From the East....
