False, they center the drum. Not a crucial component but they do serve their purpose. http://siteground237.com/~gunsandr/s...ke-Drum-Screws
Much easier said than done. The stock series axles are simple to work with. The taller ratios in the pre ABS Discovery 1 or Range Rover axles will make it harder for your truck to climb those hills of vermont unless you have the power to turn them. Also the rear axle may bolt up trouble free with minor welding, but replacing the front axle will introduce a slew of problems with the steering geometry, and unless done properly, it will introduce the undesirable handling sensation known as bump-steer.These axles may be in the picture for you later on down the road if you're planning some serious modifications and have the knowledge and skills to carry them out, but for now they would introduce unnecessary complications and hassles.
If you do go for the parabolic springs with military shackles, it will alter the angle of your pinion, which is easily corrected with shims like these: http://www.bluetorchfab.com/Product/...-4-Degree.aspx It is a common and easy modification.
A car needs to do three things, start, stop, and not catch on fire. Focus on achieving those first and then worry about modifications later. You'll find that these are incredibly capable machines bone stock, get it going first then figure out what you personally think needs improving next.
-Rob
-Rob
