The plot tickens (series III backfire/idle, brakes)
  • Nium
    replied
    I concur with taking it to the mechanic.
    Leave a comment:
  • kevkon
    replied
    So now I have to decide if I send it away or keep puttering...why does it live to taunt me?
    I sure hope it was only the quality of your recording, but that motor sounded like it lost a cylinder. Take it to the LR mechanic, have him check it out. Learn from him. You and the Rover will be the better for it.
    Leave a comment:
  • Nium
    replied
    Basics
    Distributor = dizzy
    4 stroke engine
    Each of the 4 cylinders have 4 individual strokes they go through. From TDC with the rotor pointing at the corresponding spark plug wire location inside the distributor cap. The piston goes thru these 4 strokes.
    1. Power-The spark plug fired igniting the air/fuel mixture pushing the piston down from 6 degrees past TDC. Intake and exhaust valves are closed
    2. Exhaust-The piston has traveled to the bottom of the cylinder the energy from the burning air/fuel mixture's ignition has been spent and the piston is now traveling back up to the top of the cylinder. The exhaust valve is open.
    3. Intake-At the top of the cylinder the exhaust valve has closed. Just after TDC the intake valve opens allowing the piston to draw in the air/fuel mixture as the piston travels to the bottom of the cylinder.
    4. Compression-At the bottom of the Intake stroke the Intake valve closes. Now both Intake and Exhaust valve are closed. The piston now travels to the top of the cylinder compressing the air/fuel mixture for ignition just after the top of the compression stroke.
    There are 4 lobes on the distributor shaft. Each lobe (one of the 4 corners of the distributor shaft) corresponds to opening the points for a cylinder. When the following arm of the points rides up onto the distributor shaft lobe the points are opened. The open points trigger the spark from the coil. You want the points to open just after the piston has moved a few degrees past TDC so it pushes the piston down on the power stroke and not backwards into the compression stroke. After triggering the spark from the coil the distributor shaft rotates thus closing the points (once again completing the circuit to the coil) allowing the coil to build the charge for the next opening of the points.
    For static timing you need a 12 Volt test light not a timing light or timing gun.
    Check that the low tension lead wire isn't broken inside the insulation. Disconnect it from the coil and from the connection to the points. Test it for continuity with a multimeter set to read ohms while flexing the low tension lead where it connects to the points. You want no resistance in the low tension lead. Continuity = no resistance.
    Or just keep turning it over till it fires up again. Pour a little gas down the carb throat (1/4 cup or less) to see if it'll fire with that.
    Leave a comment:
  • NickDawson
    replied
    gas - check
    Low tension still connected
    I should say that I'm doing this without a timing light. I still cannot for the life of me turn the engine over by hand (oddly even in neutral the front wheels would not spin when off the ground) - but again, when it was running it didn't lurch, crawl or make any suggestion of going forward on its own...
    So I know its probably silly without a light, but help me understand some basics here. I had the rotor button lined up on the first plug, and the timing mark on TDC (as per the manual). Do I understand correctly that I want the points to just be closing at the point? If so, why do I want a spark when the first cylinder is all the way at the top?
    Also, I can get the points to close at two locations on the inside of the distributor, when they've just been open and when they are just about to open again (make sense?) which is it that I'm looking for?
    In other words, they seem to be closed when they are on the flat side of the spindle in the distributor (is that the dizzy by the way?) and they open when the spindle makes a turn on the 4 corners.
    Just trying to better understand how this contraption works
    Leave a comment:
  • Nium
    replied
    Is there gas in the tank?
    Check the low tension lead.
    Leave a comment:
  • NickDawson
    replied
    Gentlemen, for a brief moment tonight, I held dominion over machine.
    I'm not a father yet, but I have to imagine its similar
    I couldnt find a static timing night and thought I'd goof off for a few minutes before packing it up. I tried to static time it by eye, getting the points to open just before TDC (the manual says to static time closed at TDC for #1). That actually worked.
    It ran for a good 10 minutes, pretty rough at first, pouring black/brown smoke out of the exhaust as it cleared the cruft. Once it warmed it I was able to try and dial it in a bit... it was still rough, if I gave it gas it sounded gnarly and would backfire...LOUDLY!
    I used the timing gun and dialed it in even more and it smoothed out. Then I set the idle on the carb and it was purring I tell you... still not totally smooth at higher revs (remember that busted vacuum line to the advance?) and then it died. For no reason, it just kind of petered out and I can't get back to that happy place. I do, however offer proof
    Leave a comment:
  • JimCT
    replied
    More to it
    The rotor needs to be pointing to the #1 wire.
    Leave a comment:
  • NickDawson
    replied
    Why can't i quit!
    Its soooo close to firing, if I crank it or 30 seconds or so it fires once or twice but never catches.
    I've got the green bible in hand and am working on the static timing - giving it one more shot before it goes to the Rover hospital tomorrow. With everything in neutral I am still not able to fully turn it over. When I try the fan, the belt just slips. If I really jerk on the belt I can move it about 1/4 turn in each direction, but not all the way around.
    I got lucky and got the timing mark to line up by turning it over with the starter motor.
    Leave a comment:
  • NickDawson
    replied
    Originally posted by Nium
    If you wanted to give static timing 1 last go before you had it towed. Put every gear lever in the neutral position.
    Fairly sure I did that, but could have missed something... will verify tonight since I need it to roll onto the flat bed tomorrow
    Leave a comment:
  • Nium
    replied
    If you wanted to give static timing 1 last go before you had it towed. Put every gear lever in the neutral position. Main gear lever selector, transfer box selector (red knob), and the overdrive gear lever selector (if you have one). I don't really think it's some foreign object in the engine it really seems like you still had the tranny engaged and that's why you couldn't turn the engine by hand with all the spark plugs out. With the tranny in neutral (all selector levers) you should still be able to turn the engine by hand using the cooling fan even with the spark plugs in.
    Leave a comment:
  • Bertha
    replied
    Originally posted by NickDawson
    I've got a compromise...its not exactly quitting...
    We have a family mechanic friend about 2.5 hours away who works on Series trucks a lot (has one in his shop now and serviced the Series that got me hooked for years before it was sold). His son-in-law, coincidentally, would be well known to Va rover folks since his family hosted rallies at their farm for several years.
    In short, I trust the guy with my truck.
    I can get it hauled down there for a reasonable price (thankfully got that option on my insurance). I can't spend a week with this guy, but I can spend an afternoon with him learning. I've asked him to walk me through whatever he does and he's agreed to work with me and show me what's what.
    If I can get it running and passing VA inspection for a few hundred (fingers crossed) then its money well spent - and with what I've learned so far I'll be in a MUCH better place to be able to keep it running. I think its the next best think to having a rover sage locally.
    Thanks for the help thus far folks, I'll keep you posted!
    This is the best move/plan you have come up with so far. Let us know your findings after that afternoon session with him.
    Leave a comment:
  • NickDawson
    replied
    Leave a comment:
  • Nium
    replied
    Old Plugs
    What's the gap on that plug and the other old ones you pulled out?
    have been harboring concern about a blown head gasket since the first time I saw coolant on the block
    That's not how a blown head gasket manifests. The coolant leaks into the cylinder and is displayed as constant white smoke out of the exhaust after the engine is warmed up and at operating temperature. When the engine is cool, white smoke isn't uncommon due to condensation in the exhaust system being burned off.
    Leave a comment:
  • kevkon
    replied
    Do yourself a favor Nick and sloooow down! Concentrate on the ignition and getting the motor running before worrying about broken valves and such. Try to keep it simple. Read the manual. Take the ignition diagnostics step by step.
    Leave a comment:
  • NickDawson
    replied
    Nick,
    Right now though I have to walk away from the computer before I hurt it. I would imagine you can relate after your fun with Rover today.
    You have no idea how true those words ring!
    I have the basic idea of how a compression test works - and have been harboring concern about a blown head gasket since the first time I saw coolant on the block (very very minuscule amount which may have been solved by replacing the thermostat and gasket - not sure b/c it has been driven since).
    Do these plugs tell anyone anything? When I pulled them out, they smelled of gas. When I run the try and crank it over (15 seconds or so) I can smell gas under the hood - no leaks or drips.
    Leave a comment:
