  • siii8873
    • 1013
    westcoastkevin,
    what vehicle are you working on? Backing plates are different than the SIIa or SIII's I've worked on.
    This assembly work begs a question. The bearings in the hub are lubricated with the gear oil in the swivel pin housing. Should they be packed with grease also?
    Good looking work!!
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • o2batsea
      • 1199
      Originally posted by willincalgary
      Installed a bed in my 88". I will be living in the truck for five weeks in June so I needed a comfortable place to sleep. The front support rests on the bulkhead while the rear support is attached to the wheel well.
      What you have there is what is known in maritime circles as a "pipe berth".
      • willincalgary
        • Mar 2008
        • 127
        I assume that is because it is made of pipes?
        ____________________________
        1959 Series II 88"
        "Grover"
          • 400
          I believe Kevin's truck is a 1951 Series I 80". I too, grease the hub bearings on installation. I figure the grease and oil would always mix....
          Today we hauled 20 bags of mulch in the Kalahari Disco, mounted the replacement hi-amp Delco alternator on the wife's V8 109 and removed the 88" tub from an old trailer start the rebody on my rolled SIII 88.
          Originally posted by siii8873
          westcoastkevin,
          Good looking work!!
          • east high
            • Jan 2008
            • 337
            Oil change w/ zinc additive, new cap, rotor and plugs, valve adjustment, greased my GBR bushings, topped off the tranny oil, and swapped out the speedo for another one I had laying around. My old pal is happier than ever before.
            Next on the list is either the winch or soft top and tailgate.
            '67 sIIa 88
            • Duckman
              • Sep 2010
              • 43
              Spring hit Texas full force yesterday, it was 80 degrees outside.
              Based on this I got the Landy into summer mode - rolled up the sides and took the doors off. Nothing like a little additional air conditioning.
              sigpic
              1974 Ex MOD Series III Lightweight/Air Portable
              • redmondrover
                • Nov 2007
                • 102
                bulkhead
                Not today, but recently removed the bulkhead from my 1959 88 pickup to get it galvanized (along with the core support and other metal bits). The real project is installing a new wiring harness but I could not pass up the opportunity to protect this near flawless bulkhead while I had so much of the front end off. I did not have to cut, grind or drill a single bolt. All eight of the fine thread hinge bolts came loose without any effort--or PB Blaster.
                Bulkhead and other bits are getting chemical stripped in Portland. I'll have them back in about 2 weeks and then it is off to the galvanizer!
                • rosims
                  • Jun 2010
                  • 71
                  Salisbury and Detroit Locker
                  Can't believe the difference it makes . Well worth it.
                  sigpic
                  2006 LR3
                  1967 109 Station Wagon
                  M37B1
                  M38A1
                  • JimCT
                    • 518
                    detroit
                    did the same with our '68 ambulance and it became a different truck You will be amazed
                    1963 Unimog Radio box
                    1995 LWB RR
                    • westcoastkevin
                      • Jan 2011
                      • 162
                      I will admit to some envy for you guys with ready to drive rigs. I love the stories of the spring drives.
                      Today, I got a few things done.
                      I got the correct number of shims in place to set the bearings for the output shaft in the transfer case.
                      I got the bell housing on my gearbox and got the selector levers in place..
                      I stripped my clutch withdrawal housings to choose the best one to build up.
                      I placed an order for some ignition system parts.
                      ... It never ends....
                      • rosims
                        • Jun 2010
                        • 71
                        Took 2 years and a lot of work. But well worth it!!!
                        sigpic
                        2006 LR3
                        M37B1
                        M38A1
                        • Skookumchuck
                          • Oct 2010
                          • 269
                          Bought it a new Battery
                          1968 Series IIA
                          1987 D90 Kid's project
                          German wirehair Pointer (Wood Hound)
                          • willincalgary
                            • Mar 2008
                            • 127
                            Suspect I broke a rear halfshaft pulling away from a stop sign at the grocery store. That must have been one seriously fatigued shaft. I will have to pull the shafts and confirm.
                            1959 Series II 88"
                            "Grover"
                            • martindktm
                              • Jun 2008
                              • 218
                              Installed my home built tow hitch. I did not want to weld on my galvy chassi so I built my own bolted version.
                              • Ncrover725
                                • Jun 2011
                                • 259
                                Productivity
                                I was no where as productive as you guys. I took my 109 to the local park and slept in the back of it to avoid the 2 day old baby who kept crying. I was a slacker!
                                1971 Ex Mod IIA 109
                                1985 D110
                                1998 D1 (Sold)
