  • westcoastkevin
    • Jan 2011
    • 162
    Well, I got a little more done today. The deer flies almost ate me for lunch though so it was no fun. First, I decided to do a little investigation. The bumpstops for the back axle were a little swelled and I suspected rust packed between them and the chassis. So I cut them off.
    One even had a hole.
    I cut away the old steel so that there will not be a rust sandwich in future and made two new ones. I will weld these all the way around and that should be the last of that in my lifetime.
    Then I got back to the dumb irons. I got them mocked up with the jig and the joints figured out and marked.
    I trimmed the noses and made the critical cuts.
    It is hanging from the cross holes at the textbook location. It fits pretty good.
    And from the outside.
    I got both the left and right sides done this far along.
    Tomorrow, I need to make backing plates for plug welds. I also need to but the braces in the nose of the dumb irons and drill the bumper mount holes. Then I can weld up the dumb irons and tack them in position and hopefully welded up.
    • pitchrollyaw
      • Apr 2012
      • 58
      Installed pedal pads. Guess I am getting over the hump on this project if I am installing pedal pads...
      '72 Series III 88 "Greenie"
      '85 90 2.5NA "Stinky"
      • knac1234
        • Nov 2010
        • 442
        Washed it and consequently broke it. Sorry, had to post here for a sanity check
        Julian
        Julian
        72 Series III NAS
        03 Disco
        65 MGB / 73 MGBGT
        71 RHD Hillman Super Imp
        • 73series88
          • Oct 2009
          • 587
          I took my top off and put my series doors back on
          Then it rains.
          67 series 2a 88 RHD sold
          88 RRC sold
          60 mga coupe
          • 4flattires
            • Aug 2007
            • 424
            Replaced a tire on my front end loader so I could drag out the 109 for its fender removal to get to the clutch m/c. Both jobs were successful!
            64 SIIa 109 all stock
            69 SIIa 88 all stock
            Old tractors
            New Harleys
            Old trucks
            • westcoastkevin
              • Jan 2011
              • 162
              Work has kept me busy but I got a little done today. I welded up the dumb irons themselves. Then I made two strips to set the width of the legs when I finally attach them. I will have one above and below and bolt them through the bumper mount holes.
              Then I figured out what I want to do for backing plates and got some of the work done.
              I cut a backing piece and got it welded in.
              I cut some strips for the sides and drilled the holes in the chassis to plug it in too.
              Then it got dark and I am about out of gas for the welder. This thing is taking way too long.
              • jonnyc
                • Dec 2011
                • 176
                Drove it happily!
                Oh, some twit in a Jeep waved. I got to give him the "Hairy Eyeball." That was fun. Honestly, don't they know the difference?
                • bkreutz
                  • Apr 2010
                  • 408
                  Originally posted by jonnyc
                  Drove it happily!
                  Maybe his other vehicle is a Rover? (look at my signature, the two aren't mutually exclusive)
                  Gale Breitkreutz
                  '03 Disco
                  '47 CJ2A
                  • jonnyc
                    • Dec 2011
                    • 176
                    Maybe, but it was a big shiny thing with huge balloon tires and every bit of wanna-be off-road kit you could imagine, not a nice old CJ.
                    • Escargo
                      • May 2008
                      • 65
                      Well not today but several weeks ago...Replaced broken axel in my lla 88. Got help from a mechanic friend with a lift. Lift made it much more pleasant. Not being experienced, I guess I also wanted someone nearby who could help. He let me do all the work. Had to take down the Differential as a chunk of axel was lodged in it. Knocked that thru with a long punch. Not nearly as complicated as I thought it would be. Everything went back together fine. Now I have to figure out what to do about my transmission leak. Don't know exactly where it originates but it is keeping the crossmember from rusting.
                      • 1971Series88
                        • Dec 2011
                        • 172
                        Put my floor mats and tunnel cover on from our hosts! Almost bloody well civilized now
                        1963 Series IIa 109" 5 door Safari top (SOLD to new home)
                        1971 Series IIa 88" Soft top (SOLD to new home)
                        1995 RRC - LWB
                        2001 Discovery II SE7 (SOLD to new home)
                        • bkreutz
                          • Apr 2010
                          • 408
                          I can understand that, mine has none of that stuff, if it wasn't available in 1947, it isn't there. (it does make the Rover feel like a Rolls in comparison though)
                          Gale Breitkreutz
                          '03 Disco
                          '47 CJ2A
                          • TedW
                            • 887
                            Craig:
                            Post some pics of your 109!!
                            Ted
                            • jonnyc
                              • Dec 2011
                              • 176
                              "Rover feel like a Rolls"
                              HAHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!
                              • giftshopduane
                                • Feb 2009
                                • 103
                                Its not my Series but it means just as much to me if not more... I'm happy to have it back on the road since last year. 0 mile 4.0 going in, decided to give the 210k 4.0 a rest for now. Been driving it for 2 days now, very happy.
