  • Partsman
    • May 2011
    • 329
    Painted the tailgate
    Series 2 Club Forum
    Andy The Landy Shop
    • RoverDover
      • Jan 2010
      • 144
      I installed a rebuilt Bosch starter to replace my old Valeo unit. What a difference! no more fingers crossed at 10 below anymore. it must crank the engine twice as fast!
      67 angry hamsters
      • east high
        • Jan 2008
        • 337
        Sounds like you're working on an old airhead.
        '67 sIIa 88
        • Les Parker
          • May 2006
          • 2020
          Ted,
          Les,
          Is RN going to offer just the rear kit like you do the fronts?
          Jim
          I guess we could, though no one has requested it. A kit can be put together on an as needed basis, using kit pricing/quantities. Do you need a kit?
          • Jim-ME
            • 1379
            I do plan to add rear disc brakes. Your front kit was great. Being able to buy a kit just makes life so much easier because it has all that is needed for a solid replacement.
            • ArlowCT
              • Jul 2008
              • 238
              Cleaned up my exhaust manifold, coated everything with never seize, installed intake/exhaust manifold, and spent two hours wondering why Land Rover started the assembly line with the down pipe!
              • busboy
                • Nov 2012
                • 202
                For many years I used to think that too, it was difficult to get everything realigned after an engine or manifold removal, then recently with the body off the frame I installed a completely new exhaust system front to rear and I was surprised at how much give and take (wiggle room)) there was. The exhaust was very reasonably priced, readily available and it sealed very nicely at the manifold which was not always the case.
                • ArlowCT
                  • Jul 2008
                  • 238
                  Last time I did this job was when I did a frame off and you are right about how easy it is at that point. The new system is full stainless and looks like it will seal well to the manifold but will not go in without raising the motor/transmission off their mounts. I guess I know what I'm doing tonight!
                  • jac04
                    • 1884
                    The new system is full stainless...
                    Which stainless system did you get? If a NRP, PM me for some installation tips.
                    • AustinK
                      • Sep 2012
                      • 32
                      After months apart I finally started the re-assembly of the Dash and wiring. I also got my new seats and seatbelts installed in my 109 5 door with about 2 inches of extra travelClick image for larger version
ID:	167699Click image for larger version
ID:	167700Click image for larger version
ID:	167701Click image for larger version
ID:	167702 - the next challenge is rear seat from the same donor. I also took a first crack at the flaming river steering column upgrade. Made custom brackets pictured here that almost look stock. The tilt wheel will be very nice with my uh - extra middle section.
                      • blue bomber
                        • Dec 2011
                        • 48
                        Installed my radiator, ford brake mc, iron clutch mc . As well my 1000 HP air filter!!
                        These modification have been put off because everything was fine. I flopped the car and decided to make these changes. While off the road . (
                        No cool story for the flop. Just not paying attention on a slimy road.
                        Tapatalk sucks, sent from Matthew's IPhone
                        • blue bomber
                          • Dec 2011
                          • 48
                          Originally posted by AustinK
                          After months apart I finally started the re-assembly of the Dash and wiring. I also got my new seats and seatbelts installed in my 109 5 door with about 2 inches of extra travel[ATTACH=CONFIG]7828[/ATTACH][ATTACH=CONFIG]7829[/ATTACH][ATTACH=CONFIG]7830[/ATTACH][ATTACH=CONFIG]7831[/ATTACH] - the next challenge is rear seat from the same donor. I also took a first crack at the flaming river steering column upgrade. Made custom brackets pictured here that almost look stock. The tilt wheel will be very nice with my uh - extra middle section.
                          Nice. What are you using for a steering box?
                          Cheers, Matthew.
                          • AustinK
                            • Sep 2012
                            • 32
                            I plan on using a 2007 jeep wrangler 4 door LHD gearbox. I spent time looking and in teh US for a RHD drive this seems to be the best shot.
                            • NDNAJNS
                              • Jan 2012
                              • 42
                              I'm replacing the head-to-manifold gasket. First project on my new rig! Got the manifolds out...no broken studs! A little PB Blaster helped. ...back to prepping/cleaning...
                              Cheers.
                              1965 88 Petrol
                              2009 MB C300
                              • busboy
                                • Nov 2012
                                • 202
                                Cheers.
                                Make sure the exhaust will bolt up again before tightening the manifold down to the head.
