  • cedryck
    • Sep 2010
    • 836
    Top up, 90W in swivel balls, rear, and front diff, gearbox, and transfer box. Making ready to change crankcase oil after a run to the local auto store for the appropriate oil. Also cleaned a couple of months worth of Terrier slobber from all five rear windows in atop the tub, this enjoyable physical arm activity takes nearly an hour as the two Terriers have what seems to be industrial strength, long lasting, viscous, thick, oral slobber that only goes away with lots of Windex, and a copious amount of arm motion. Now I can see through them again.
    • caperover
      • Jan 2012
      • 33
      and blanked off extraneous openings. Had inside of tank epoxied.
      Began the refurb of an FFR gas tank.
      Drained old varnish, removed tank, - washed with phosphoric acid and chains. Viewed hundreds of pinholes from inside.
      Procured new side fill tank - had top fill cap cut off of old tank and soldered to new tank. Blanked off other filler holes.
      Resurrected 24V. fuel sender. Drilled out rivet holding spade terminal, listed out wire wound resistor, unwound 2 turns, reinserted resistor, inserted new spade terminal (swedge fit), and re-soldered.
      Next steps: Add replacement float and arm, repair fuel line pickup
      • DGG
        • 304
        Refurbished my oil/water gauge. painted the needles to match the new VDO gauges that are going in.Click image for larger version
Name:	H2o and oil gauge.jpg
        Doug
        61 Series II 109 SW
        95 RR County LWB
        06 Range Rover
        98 Discovery LE
        • 80sailor
          • Feb 2014
          • 98
          Installed new,upgraded alternator.
          And it works!
          • MJL
            • Oct 2007
            • 85
            I drove it !!
            Sad to say but I hadn't driven my Series III since last December except for a short trip for its State inspection at the end of April. Today I was determined to start and use it again. It started on the first turn and I drove it out of the woods were it had been parked, gave it a good wash and then took it out for a drive.
            I know it's a sacrilege to have treated it this way, but I promise to try and do better for the rest of the year.
            • cedryck
              • Sep 2010
              • 836
              Drove Rover through a small trail with loads of mud to dress it up for the Comvec Show at Chester. Cannot show up all pristine and clean!
              • siii8873
                • 1013
                well this is actually over a few months. I rebuilt my 1954 2.0liter Siamese bore engine; cylinders bored out, new pistons, rings, mains, big ends, gudgeon pins/bushings, cam shaft, camshaft bearings, exhaust seats, exhaust valves,,..
                Went to start it for the first time last weekend, it fired up and ran nice for about 10minutes then coughed a few times and stalled. Have not been able to get it to fire more than a few seconds since. Checked fuel pump and it's pumping fuel and plugs smell gassy. Have not been able to figure out where I'm loosing spark yet.
                THING 1 - 1973 88 SIII - SOLD
                THING 5 - 1958 109 PU
                THING 6 - 1954 86" HT
                • Correus
                  • May 2009
                  • 31
                  I reinstalled Grover's engine and transmission today as well as a few other smaller things as well.
                  Cheers!
                  Larry
                  1963 IIa 88 Station Wagon
                  • johnny2rovers
                    • Dec 2013
                    • 59
                    New Canvas!
Name:	New Canvas.JPG
                    '65 Series IIA, 88'
                    '00 Discovery II
                    '08 Jaguar xj8
                    '95 RRC LWB, deceased.....
                    '75 Forward Control GS, 72 FL 64, gone to CA!
                    • 49thstaterover
                      • May 2018
                      • 2
                      In the last two weeks:
                      1972 Series III, petrol
                      -First oil change as owner. New racing oil with extra zinc used! Valvoline I think. Filter canister had some metal in it- uhoh! How long it has been there is anyone's guess. Emptied air cleaner and filled just outside as the entire bottom was full.
                      -Rebuilt Rochester carb to replace generic zenith that was on it temporarily. Ran terrible until rochester was on again. #48 jet inside. Have an extra #53 but mileage is already bad, left #48 in. Reset timing. Checked mileage. Better. Will have to get an O2 sensor and see if I'm good on the tune. Safety wired throttle screw and installed spring to keep from backing out.
                      -Filled everything in sight with 90w- some places took more than others, but had probably been a while since checked.
                      -Working on steering relay- seems to have a leaky seal that causes steering to get real vague after a week following a refill. A larger project coming it seems.
                      -Washed it! The moss in the window tracks is still present. We don't get many 75 degree days in Alaska, so seemed like the thing to do.
                      -Replaced a fuse for turn signals.
                      -Took my wife for her first ride. She laughed. It's a tractor.
                      Next up:
                      -Hard pull to right under braking.
                      -All lights functioning
                      -Gas gauge
                      -Reinstall shoulder belts
                      -Tachometer and maybe a hand throttle
                      -Wax the paint that is still present and accounted for?
                      • 80sailor
                        • Feb 2014
                        • 98
                        I put an insulating wrap on my fuel line to try and help with vapor lock here in the Texas summer.
                        Next up for this coming weekend is the annual full fluid change front to back. Diffs, t-case, trans, engine...
                        • lumpydog
                          • May 2014
                          • 383
                          80 - what wrap did you use. Can you share results?
                          1968 Series IIa
                          • 80sailor
                            • Feb 2014
                            • 98
                            Sure.
                            This is what I bought (thermal sleeve) but I picked it up from NAPA instead of Jegs.
                            So far, so good. And the last few days have been hot here in Texas.
                            I figured for the price it was worth a shot.
                            • 80sailor
                              • Feb 2014
                              • 98
                              Today I installed a new Interstate battery. The PO had, for some reason, put a deep cycle marine battery in the Rover. Not surprisingly, the Texas heat killed it in this application.
                              Next week my new hoop set and canvas arrive so I can finally have a soft top!
                              • lumpydog
                                • May 2014
                                • 383
                                Originally posted by 80sailor
                                Sure.
                                Helpful! Thank you
                                1968 Series IIa
